I knew you had a Cox Trainer.I'm not sure, the tether rope my wife has tied to my airplane only lets me go so far and then I have to be back for supper !
Are you sure about that? Do architects have to take them into consideration?When I get out of the shower, the water clings to my ball sack all the way around. That's not a flat surface.![]()
I suppose I could get an Architect in with his theodolite and take some readings?Are you sure about that? Do architects have to take them into consideration?
Wow man, but which one gets to Duesseldorf first?On an ocean voyage as an example - two yachts sail directly out from port, after about 25-30 miles, they both disappear form view.
And yet oddly enough, the crew on both yachts can still see each other, and notice no change in their position relative to the sky and water surface. No bumps or slides are experienced when they are lost from sight by the people on shore.
Spooky stuff.
The one driven by Bob.Wow man, but which one gets to Duesseldorf first?
And, I'm never getting on a cruise ship again.
Do ya member dit one???That song still isn't familiar. I remember the band but not that song.
Spooky stuff.
How about the space shuttle, or satellites ? Are they in orbit, or do they just sit there in place ? And yes, if you do research, you'll know when constructing long-span bridges, the curvature of the earth is calculated into the design. I learned that as a kid when they were building the Verrazano Bridge in NY.Do planes fly level or follow the curvature of the earth?
Do architects take into consideration the curvature of the earth when designing large items?
Plaines flying level? I was thinking about that but hadn't posted yet. Trimming the elevator keeps the plane at a near constant altitude. (the elevator is the flaps on the tail section and control the plane's nose up and down) Say you are flying level at 1000 feet you will gain altitude the further you fly. You need to make adjustments to cause the plane to nose down to follow the curvature. I wish I could explain it better. I took a small commuter flight to Chicago once. If I remember, only one seat on each side of the center aisle. It was a small plane and the pilot kept the door open to the cockp[it so I could watch him fly it. Once we got to altitude he kept adjusting the controls and I bet it was to maintain altitude. You could feel the plane change pitch just a bit when he did.Ignorance is a learned skill that closes the open mind to understanding reality.
Instead of making fun of what you think is "true" because your programming is over ruling any form of logic left in the brain - look at the questions BOTH sides raise in the discussion.
Water is flat is it not?
Flat means level. Do planes fly level or follow the curvature of the earth?
Any pilots on here?
Do architects take into consideration the curvature of the earth when designing large items? Any architects on here?
Doing the curvature of the earth math reveals interesting phenomena...look it up instead of making fun of what you don't know or understand
Nope.Plaines flying level? I was thinking about that but hadn't posted yet. Trimming the elevator keeps the plane at a near constant altitude. (the elevator is the flaps on the tail section and control the plane's nose up and down) Say you are flying level at 1000 feet you will gain altitude the further you fly. You need to make adjustments to cause the plane to nose down to follow the curvature. I wish I could explain it better. I took a small commuter flight to Chicago once. If I remember, only one seat on each side of the center aisle. It was a small plane and the pilot kept the door open to the cockp[it so I could watch him fly it. Once we got to altitude he kept adjusting the controls and I bet it was to maintain altitude. You could feel the plane change pitch just a bit when he did.
Indeed. The aircraft's movement forward is against the atmosphere. Without going into the physics or the equations, simplified it is what he stated. Gravity is the rope. Gravity is a constant. Just like satellites and the big, round ball of cheese in the night sky... the moon. They don't fly off into space due to... gravity.Nope.
Aircraft are in a sense tethered to earth, by gravity.
