Mike67
That's good news if that fixes your issue I guess...I hope he is redoing it for free now that he came clean!
I bolted a length of perforated angle steel to the yoke and leaned on the nut a little with an 18 inch breaker bar and piece of pipe on the end without moving it. I'm kind of suspecting a bearing shell wasn't fully seated but if so I would think the pinion nut would initially move without too great an effort. I'll carry it back over to the shop guy in the morning and let him figure it out.
Since it was quiet on the drive side I have hopes that when he gets the pinion tightened back up and the backlash in spec it will be OK. I can live with a slight whine on coast - the torqueflite planetary gears whine anyway when it downshifts into lower gears. Probably drown it out at lower speed.
It's easy to put thicker shim in the front of the pinion if that's what's needed.
It wouldn't have to come apart.
You need a "yoke holder" about 2 feet long made of 3/8 or 1/4 steel to get enough torque to pull snug on the nut.
Or a hellacious big vise.
Before my father made me this tool, I got by with jamming something between the yoke and and the snubber mount,
but it was iffy.
Back when I beat up rear ends I don't think we had crush sleeves.What do you think about his re-using the crush sleeve with the new gear set instead of a new one?
Hi: ar67gtx
Followed you here from the earlier thread. While you'll get many opinions on all things driveline related, I need to drop this fact, if you run the diff any significant amount of time with no preload on the pinion bearings, i.e. pinion movement noticeable by hand manipulation, it will for sure fail in short order. If you want to save these gears that has to be rectified. You can debate the amount of backlash and the exact shape of the pattern, but zero preload with pinion movement, and it's only a matter of time. From what I've read here so far I wouldn't trust your mechanic with this, you've given him multiple chances to fix it, it's time for someone else to look at it.
I would use the crush sleeve eliminator kit. Makes the rear stronger and can be set up correctly the first time.
