funknut
Looking good, Hawk! I'd show you the pics from some of my welding projects but I destroyed all incriminating evidence.
That would be great and a lot of fun. OK, you can buy first round, and then we'll have to argue about the next one!Hey HawkRod, overall it still sounds like a good trip. The car looks Great!!. Winter is coming fast and I am still hopeful that I can get at least decent road trip in but we shall see. Cannot wait to see your car in person. I told Builderguy we need to meet up with you when you do your road trip. I am buying the Beer.
Yep same here. Need to get the some gremlin resolved as well. SpeedO is jumping all over, tach as well. Heater fan does not turn on the fan. Stuff lime that. Looking forward to those brewski'sThat would be great and a lot of fun. OK, you can buy first round, and then we'll have to argue about the next one!
Hopefully I can get some of the gremlins out of mine to ensure it is reliable. I just got back from visiting family in Los Angeles, so there has been no progress on my car in the last few days. I MIGHT take it to head down to skyline drive this weekend, but not sure the weather is looing good enough for that. Will check weather forecasts tomorrow and see how that looks.
At the moment, my 'Vette is on the lift with a leaky fuel pump, so I guess I'll rebuild that first and then throw the 73 back on the lift for other stuff. Always something to fix!
For many years I have had a harmonic vibration at about 65 MPH. It is annoying. Damn it, it is still there, and darn near the entire drive line is new. I have confirmed that it occurs at 65 MPH regardless if the O/D is on or off, so that says it MUST be the driveshaft, rear axle (or maybe the overall drivetrain angles). I have to deal with this and fix it. It is extremely annoying.
Thanks for the advice - I will take all I can get!Drive down the road and maintain speed where the vibration is the most severe. Shift vehicle into neutral. Is vibration same, less or worse? I do this sort of thing as part of my day job.
OK, I put the old wheels and tires back on, and took it for a drive again. Short answer to your question is "less".Drive down the road and maintain speed where the vibration is the most severe. Shift vehicle into neutral. Is vibration same, less or worse? I do this sort of thing as part of my day job.
I'm just shy of 5 hours away from Pittsburg.How close are you to pittsburgh? I have a pico scope with the NVH pack that we could use to pinpoint it. I get out close to the border for work and might be able to swing by
Thanks!Hawk, since the vibration is worse under power, when the rear axle is under load and trying to rotate upwards, then I am thinking you need to add some shims to create more of a downward angle at rest. Probably doesn't require much. I used to run 4 degree shims in the cuda, so that the driveline angles lined up under hard acceleration.
My ‘79 Magnum has the ISO mounted suspension. I was out a tiny bit on the angles. I “RoadKilled” it by using thick washers under the between the spring and the rear.Does the 73 have the rubber isolated mounts on the spring? If so you may have to change them for solid ones in order to use the shims.
Thanks Don. I'll look up the rust penetrant oils. Much more rust repair to come!I was over at a friends the other night.
He swears this is the best stuff, after all Mopar knows rust better than anyone.
You don't need much which is good because it's pricey.
You need to shim the rear you can't just twist and tighten.
Yes, it does have the rubber mounted springs. I think, as rumblefish360 states, it is called the ISO suspension. It has been so long since it has been apart that I am not sure how I would shim it. I'll look up some drawings tomorrow and see what that tells me.Does the 73 have the rubber isolated mounts on the spring? If so you may have to change them for solid ones in order to use the shims.
I am NOT above RoadKilling it! I would certainly be up for using some washers if it could help prove what I need. If it works, then I'll gladly make or buy some appropriate shims.My ‘79 Magnum has the ISO mounted suspension. I was out a tiny bit on the angles. I “RoadKilled” it by using thick washers under the between the spring and the rear.
Not a recommend path to take but it worked for the driver it is.
So I measured my drivetrain angles with the new digital gauge. I think the important point here is that while my car was in the garage, it was not necessarily leveled. My garage as a slight downslope (as I believe most do), so the key here are the relative differences.
I went to adjust the rear a bit by loosening the 4 U bolts, but they were not budging. I didn't want to break them and I ran out of time last night. I will get the car back on the lift Thursday and see if I can't work the nuts loose.
- Engine/Transmission: 3.1* down
- Driveshaft: 1.1* Down
- Rear: 1.3* Up.
