Ladder bar installation is complete and the Plymouth is in hibernation for the winter.
All in place, ladder bars set at 2 degrees downward and 3 degrees pinion angle.
ARP wheel studs have been installed and winter storage tires are on. I had earlier mentioned that I had my wheel studs in the 5/8" stud holes in the rotors. Turns out that the other holes in the rotors were for 4-3/4" bolt pattern, so I was using the correct holes. I was torquing my bolts to 90 lbs, will be increasing that come next year, at least 110.
The ladder bar look is good.
The 64 is put away and the Donation Dart project rolled in.
Metal work / replacement will be both front half floor boards, a small amount of trunk floor repair, mini tubbing, quarter panel skins on both sides, stretching the rear wheel openings, frame connectors and a roll bar.
And I dragged out the rotisserie today and will be hanging the winter project onto it the next few days..
SO, being this is not a B body, I guess this thread is pretty much done until the '19 season.
