Stock distributor and the Summit Racing brand which amazingly looks exactly like a FireCore50, go figure. We set it for 16 degrees mechanical so we can start right around 20 degrees initial.
View attachment 310235View attachment 310237
And then up crops one tiny little problem, rotor phasing. The cam gear for the distributor/oil pump, intermediate shaft, intermediate shaft bushing, block and distributor tolerances have all added up so the rotor doesn't even point to the cap terminals at full advance.
Rotor's eye view @ 20 degrees initial advance. The red spot on the distributor housing is the width and location of the cap terminal.
Rotor's eye view @ 36 degrees total advance.
Let's fix it................
Here is the rotor's eye view of the rotor phasing after the fix.
@ 36 degrees total
And the fix. The stock reluctor is on the left. The slot that lines up directly with one point of the reluctor is for small block distributors and the offset one is for the big block distributors. We needed
more offset. The modified one is on the right. I had six chances to get it right and it only took two!
