All my lines have a gradual fall back to the compressor and a ball valve to dump water at the lowest point just below the inlet to my compressor. Every house has had this set up, some with sixty feet between each other. I start by laying out my drops and work my way back to my compressor, it being the lowest. This and my condo were the shortest I have done. I only used sixty feet of copper for this job, total. I use to have two air dryer setups, one at each end, those days are over and this is all I need now. The regulator in my picture, with this setup, is the system I used. You can see I deleted the air dryer and ball valve. The runs are to short now to worry about a ball valve, which is at the compressor. I had an inline dryer and oiler years ago, that quick connected for air tools, also not needed now. The older I get, the fewer my needs. I use electric tools more now, air is for small stuff like filling up tires and a few small brad nailers when I tinker with some wood projects. I'm just that easy!!!Finished my air lines and wiring for my shop and garage. It works!!!
View attachment 1569079View attachment 1569080
I've got the lead out today!
Well another off the Tadoo list! Now to fill her up and get it up to 104 to soak my weary bones after the next job.
View attachment 1570926View attachment 1570927View attachment 1570928
Water out of the well is a balmy 49F... it'll be a bit yet !Ok ok STOP right there Wayne!
I have to go to work in a few minutes.
I DO NOT want that image in my head for the night!![]()
You missed a spot!mudding away, 14 bags of easy sand durrabond, 3 buckets of all purpose for tape coat, 3 buckets of proform light, so far almost second coated. no coat tape on bead for the cathedral turned out perfect with View attachment 1570971View attachment 1570973View attachment 1570974View attachment 1570975View attachment 1570977a little help from the laser. skylight doors are working great just enough clearance, duty cycled the inline actuators at least 100 times each seems to be holding up well so far. will triple coat the beams and butt joints, for added reasurance of paint coverage, will be using a semi-gloss paint, a drywallers worst enemy.
Beware of California hot tub rectal gonorrhea!Well another off the Tadoo list! Now to fill her up and get it up to 104 to soak my weary bones after the next job.
