A short time ago I mentioned I was going to bond the inner fender brace from the rotted original fenders to the Sled City fiberglass fenders, which I did using automotive panel adhesive, and while the results looked good they actually weren't. As soon as I began installing the fenders I could hear the adhesive "popping"; it hadn't adhered to the braces and I literally just popped the braces back off
. I don't know if my surface prep was bad or what, but I was way disappointed; I've used the adhesive before with terrific results so this was kind of surprising. Maybe it was the cold temps (in the low 40's) that did it? Regardless, I've decided to go a bit different route shortly, which I'll show in some pix in a later post.
After the brace debacle I got back to gapping the doors and fenders, so here are some shots of what I've been up to.
The gap between the door and the fender has been a BITCH to get right so like the other door gaps I used Evercoat Kitty Hair to build up the leading edge of the door:
After building up the edge I cleaned it up, leaving extra material so I could final trim it once the fender was mounted, but once the fender was mounted another issue came up: the body lines were WAY screwed up! I had noticed this in one of my earlier mockups a year or so ago but now I'm finally having to deal with it. I'm not sure where the problem came from, but I do believe it was during some part of the fender fabrication (sorry, don't mean to throw Sled City under the bus) because the fenders and doors are mounting to stock factory locations. Here's what I'm talking about:
See how far down the body line is compared to the door, and the slight droop in the fender line? Regardless, I've got Kitty Hair and we can fix it!
Yea, it looks like somebody threw a pile of horse crap on my fender but the build up was necessary to allow me to adjust the line, which now looks like this:
The shot above shows the results after just one round of adjusting using the Kitty Hair and various grits of sand paper. I ran the string along the body line for comparison. The body line will get even better with some more refinement but so far I'm really pleased with the results.
One other adjustment I had to make on each fender was to move the bottom mounting hole forward a quarter inch. The mounting tab fits into a small recess so elongating the hole in the fender wouldn't give me the adjustment I need so I cut out the section, slid it forward, re-glassed the area, then built it up to push the fender outwards. Like I said, I'm not sure what kind of fender was used for the mold.
One other change I've made is to the fender mounting (shown below). The four mounting tabs shown are for the fender bolts; the bolts would pass through the tabs and into the fender, but I decided I didn't like the tabs being visible so I cut off the mounting arms (and tabs) and will replace them so they are hidden behind the fender, the bolts will pass through the fender and into the tabs. The mounting will look virtually identical but its location will be moved outward from what you see below.
