Hello guys! Long time no post! Been through a lot of thing since last time I've been posting here!
First the inner fender brace are welded.
We adjusted the taillight lenses with the quarters, wasn't an easy part.
And we did something that we are really proud of because it turned out really nice but I will be waiting on your comments for that, is that between the Dutchman panel and the quarters, you've got that little junction between them like a gutter, anyway, instead of putting some seam sealer in it, we decide to braze (I guess that is the right word) with the oxy ethylene torch in those gaps. Then with this rotating tool on the compressor we sculpted it and we've got a nice finish gutter. And now the water can flow on it without going in the trunk.
Then we went in the car, and start the floors. So we cut out the floors repaired the torsion bar crossmember on the passenger side. We cut out a piece of it then redone it with a piece of metal and welded it back. We also had to redone the reinforcement inside it. After that once the front section floor were out, it was time for us to make the front torque box. So we took a rectangular section and made a "Y" form with it. Then we welded it on the inside of the rocker and the fork of the "Y" on the frame rail. Pics will come it will be easier to understand because it is quite complicate to explain it lol
Once it was done, we fabricated our own subframe connectors as well, and I'd like to thank Bherman for his useful pics he posted of his car (the 66 resto mod street toy), because he inspired me for my conception and above all for the attachment point of the subframe co. We finally welded the whole thing up; for the driver side it was a bit longer because we had to figure it out a pass through for the e-brake cable. The subframe weren't high enough to drill it and make a hole from both side and pass the e-brake cable inside it, but it was lying on the top of the subframe and it was bending the cable. So we had to make a notch in the subframe. For tat we use a handlebar from a bicycle, cut it open in half and welded it on the subframe. So now the cable got a nice channel and it fits pretty well!
Once the subframe were in, we began the welding process of the front floor section. Tonight more welding and hope tomorrow it'll be finished.
And after that the car will be coming back from the dead! Because no more repair or body work! Wouhou! what a relief! Then just have to make the rear torque box, make some brackets for the rear sway bar, then seam sealed the whole car, and then it could go out of the house for the paint shop! hope current this summer it'll be painted.
We can finally see a sample of the light at the end of that tunnel!
I know this is a tone to read sorry about that.
Thanks for your time and I will add some pic soon!
Thomas
