Carcinogen
I had electrical issue that was intermittent. Found wire corrosion on the inside, outer insulator looked good but inside was brown with spots of green corrosion.
Not yet. I have it right here:definitely worth considering.
You just recently installed the Rick E distributor and blue ECM with matching ballast resistor, correct?
Oh yeah...
The relay has a yellow wire on it. I don't recall if the ballast has one to it. I'll look and see.
even if it's not the issue, I like this. Why don't more of us connect the ECU like this?Looking at the wiring diagram here on page 4 the ECU power is coming from the hot side of the coil? This will give an erratic signal. I think you should try a clean power source.
I had a similar problem with a Holly sniper, I ran power directly from the battery to the ECU with a shielded wire and the problem dissapeared.
do you have a link for the Mancini ECU? It's rev limiting? What ballast resistor ohm rating do you use with that setup?I have Ricks distributor and a Mancini box, I had luck with Mancinis box on my Lil red express truck so I put one on the GTX. I don’t think my 440 will live to see 7500rpm, but it’s seen 6500, and I can cruise at 70, put my foot down up a hill and get up to 100 without any hesitation or hiccups
I’m not a huge fan of msd because of the cost, but from what I’ve heard and read the new ones have the issues, the older ones are fine
The ECU Blue/Yellow gets its power off the Ignition 1 Run Side of the Ballast Resistor - Full 12V - 14VLooking at the wiring diagram here on page 4 the ECU power is coming from the hot side of the coil? This will give an erratic signal. I think you should try a clean power source.
