It's a dual field alternator with the appropriate voltage regulator. It has been working just fine in my car for 8 years, but of course now, last minute before I leave on a trip, it decides to take a crap. I may have indirectly caused it when the field wire fell off? I don't know.PITA working out the bugs sometimes...
as you have well documented it
looks great except for the blackened oil-covered headers
is it a single field reg. used on a dual field alt. ?
I think it won't charge
if it is
ground one of the fields, to case
plug it back in
or bench test it
before you plug it back in
or the regulator took a dump
they've none to do that, especially the newer ones
maybe it/the field wire arced on something, grounded took out the reg.
sorry,
best I got
Thanks - I didn't think so either. But it seems odd that I just drove it 300 some miles to my father-in-law's place and back with no issues. Then the alternator goes bad at the same time as I find a wire off (and I was making no changes to anything other than the oil pan). Did it spark and blow a diode when I tried to put it back on? Who knows?A wire falling off won't damage the regulator.
Haha. Yes, I carry a number of spare parts in my trunk - spare water pump, belts, voltage regulator, MSD 6AL box, etc., even some fuel injection modules. I try to have all the stuff that will be hard to source (and reasonably small too). Of course, I did/do not carry an alternator. Maybe that's why it broke!I had my 65 all ready for the Power Tour. The morning I was leaving I pulled into my girlfriends driveway to say good by.
Big puddle of oil and a stream line running down the street. The oil pressure sender split open.
Sh!t happen all the time.Old saying is to put spare parts in your trunk and you will never have a problem.
Alternator, regulator, spare senders and assortment of hoses and parts to plug things up.Hell I even carried a spare water pump.
Hang in there, it will be worth the aggravation in the long run.
I'm sure you'll get it figured out. If it's at the front of the engine, the timing chain cover or crank seal is what's going through my head right now. Hang in there, persistence pays off.OK, update for the day.
I got a replacement alternator. Turns out the mounting flange that the alternator pivots on is wider on this new alternator and it interferes with the bracket holding it. So I had to grind and clearance it to make it fit. Sigh. Nothing is ever easy. However, I now have a functioning alternator. One issue resolved.
Then I went driving around for maybe 45 minutes. I drove the car harder to have quick starts and stops and slosh oil around a lot. When I got it back on the lift I saw there is still an oil leak. Damn it!!! It is coming from the front of the engine - the rear area was dry.
What I'm not sure about is where specifically this is coming from; I'm not sure it is the oil pan gasket area. I'll have to check tomorrow morning carefully once the car (and me) have cooled down sufficiently.
Thanks for the brainstorming - I need all I can get right now.throwing it out there, brainstorming/guessing
because it's not uncommon
right at the corner/s of where the
bottom of the timing cover & pan intersects (maybe ?)
possibly by/where those 2 pan bolts 'come up' thru into the timing cover
(I always pay a lil' extra attention in that area too,
lil' extra, not much/dabs of silicone in the corners)
you probably already have
but;
check all the pan bolts for tight too
a wild *** softballThanks for the brainstorming - I need all I can get right now.
I am very careful with the oil pan so I don't overtighten bolts - to avoid warping, etc., maybe too careful? So I went around and tightened up the bolts further. Same $hit, different day.
I simply cannot find any source of leak above the pan (not saying there isn't one, but I be damned if I can find any). The transmission inspection cover remains bone dry inside, so I don't think rear main seal is an issue. I saw a drop or two of oil on the starter, but that seems like it was blown there since there is no oil above it; the oil pressure sender area is dry as a bone, as are the heads where oil may cling and trickle down. As you warn about in your note, I believe that the pan corners are the most likely culprits.
I have now dropped the pan again and I am going back to the old tried and true cork gasket with the windage tray sandwiched in between. Biggest issue now I think will be getting gasket, windage tray, gasket and oil pan all up onto the engine and tightened down without screwing up RTV or gaskets. If it was just a pan, it would be easy, but the windage tray add parts, plus it cannot be lifted straight up - it must be angled and twisted around the oil pickup to get it on.
Everything is clean and ready to reinstall, but I'll wait until I get another pair of hands to keep stuff aligned and help get it all in place properly.
Again, I appreciate the thoughts and help from afar!
No repair sleeve - I just put in a standard seal. I think the sleeves are for the crank nose? The front of my crank is fine and not worn. I even put the balancer on before I tightened up the cover even though it has alignment pins. Looking behind the balancer is impossible, but I have run my finger on the ledge at the bottom of the timing cover and it has been "fairly" dry. There was oil there, but it seemed more to be blown on it rather than the source. Running the car on the lift it stayed bone dry.I had an LA 360 years ago that I sealed the bottom of the timing cover by thoroughly cleaning and externally applying RTV never leaked again.
Your timing cover seal didn't come with a "repair sleeve" by chance?
I had one of those on a Magnum where I didn't use the repair seal as my balancer looked fine.
But the seal was sized for the increased OD of the repair sleeve so it leaked but not very much.
So I do feel like I got a decent look at my fuel pump area. I just have a blockoff plate and that's the area where my A/C sits. The block underneath that area has been dry. I also checked the oil pump area too, and all "finger swipe" and visual tests have come back dry.a wild *** softball
probably not even close to the leak
But;
maybe from where the mechanical fuel pump mounts (?)
or the plug (to take out the pump rod) below it, hard to see or tell
I had one leak, one time that drove me nuts,
looked like it came from a corner of the oil pan
I swore it was dry above it
& I didn't even have a fuel pump, just a block-off plate (running electric)
but it was dribbling from the plug under it
(usually only after a N2O hit too)
I put some pipe dope on that, it stopped
(I really didn't think much oil could even get there, oh well)
for good measures, I resealed the 'pump block off plate' too
I had redone the pan & timing cover & front crank seal, 1st of course
made sure to take special care of those areas up front too...
I hate oil drips or leaks with a passion...
when I finally found it, I had to laugh
sometimes it's the simplest things, you overlook or don't think of
always nice to have second eyes or good opinions to help
or just BS
I have a Passon A-855 5 speed - so essentially the same footprint as an 833. I have a 10.5 bellhousing bolted directly to the block, with, of course, the flywheel and clutch underneath (see picture below). I checked all my cam freeze plugs and pipe plugs after running it on the run stand, and all dry as a bone. Every time I have checked my inspection cover it has been completely dry inside. I'd think that if the rear main seal, freeze or cam plug were leaking it would go into that area? The back of the flywheel is also dry, and it doesn't look like it is slinging oil around the inside of the bellhousing.another crazy idea, guess
Do you have a blow-plate on the back of the block
for clutch explosions or that 'thin steel plate' between the bell housing & block
(I don't remember if it's an 727 or an 833 )
maybe a pipe plug or cam freeze plug behind that
so it's not going into the bell-housing
Thanks for the suggestion, and I wish you were on to something.I hate to say it Hawk, but the one difference from when you ran it on the run stand is the valve covers. I had an oil leak at the rear of my block I thought was the pan gasket or rear main seal. Turned out to be running down from the valve covers. I could not see where it was coming from, but tightening the covers solved the leak.
