The comp cams rockers can be a bit of a headache to get the proper size pushrods..
I guess it depends on what you’re used to.
I don’t find them to be difficult in that regard at all.
In fact, I feel like they’re actually easier........ since you’re not guessing about how many threads should be showing below the rocker to facilitate proper pushrod oiling.
With the Comps, screw the adjusters up into the rocker as far as they’ll go, then back it out one full turn..... snug the nut down.
Now use the pushrod checking tool to figure out the correct length and order them up.
Done.
As for the pinging....... too much compression with poor/no quench for the octane you’re running.
That’s (a lot)more complicated/expensive to solve if you’re trying to make it work with the same gas you’re running now.
The first step would be to take a couple of degrees of timing out of it and see if that helped.
A slower, factory styled advance curve........ and employing vacuum advance
might solve it, or make a noticeable improvement.
But..... that’s a topic for another thread.
