- 4:51 PM
- Apr 13, 2012
- Granite Bay CA
That seems to be the case.
at my job where we have a Clean Room for medical device assembly, we also use the one on the right. I never realized there are two types.Construction workers always use the one on the right.... Mechanics use the one on the left...
I must be classified as a construction worker then. All mine are like the one on the right as they are by far the most popular in my neck of the woods. I don't think I have even ever seen one like shown on the left.Construction workers always use the one on the right.... Mechanics use the one on the left...
Mine was the one on the left.I must be classified as a construction worker then. All mine are like the one on the right as they are by far the most popular in my neck of the woods. I don't think I have even ever seen one like shown on the left.
Greg and I discussed that a few times.Rich, I know that an additional cost could be a factor, but at this point with a few times that the H-pipe location has become an issue, do you have any appetite for avoiding further mods to accommodate the existing H-pipe location and just have an exhaust shop cut and weld to re-locate the H-pipe in a more user friendly location after all is said and done? That way you can also provide easier access for future repairs. You'd have a few extra welds, but they wouldn't need to replace everything back to the rear, only some of the middle section and it might be worth it.
Do you keep your tools in bags attached to your waist??? Maybe you need to try it out???I must be classified as a construction worker then. All mine are like the one on the right as they are by far the most popular in my neck of the woods. I don't think I have even ever seen one like shown on the left.
Not anymore. Used to do a lot of electrical work along with HVAC. Strictly HVAC now though for the past 26 years.Do you keep your tools in bags attached to your waist??? Maybe you need to try it out???![]()
Greg,I enjoy writing about the journey we take when making a change like this. So often, these projects are not a simple "plug and play". Most of the time, there are other changes that need to be made, stuff that gets moved, modified and altered to make it all work.
My own goal is to put out as much information as I encounter it with the goal of informing others of what obstacles lie ahead for them.
For a shop it needs to be done a lot quicker than that... Try to bill a customer 40+ hours for a transmission swap/conversion....I'd love to hear from someone that did this job in a week's time.
Seriously....The swap from an automatic to a 5 speed manual in a week. Does anyone know someone that has done it that fast?
Nice thought but usually not the case.... And if there is a spare stall it probably won't have a lift... Or there would be another mechanic working in it...Since I’ve never worked in a repair shop, I can only guess that they’d need spare stalls so the mechanics can alternate between projects to maximize profits.
