Updating the Super Street Mopar
No major issues, just getting the fit as good as I can. Not quite hugging the floor around it but some other that is the Nutserts not being flush with the metal they are installed in. Sit up close to an eight. Could buy some dies from Hammer Fab so they don't stick up but those are spendy. Add in the trunk floor above the frame rails isn't perfectly flat. Can't do the hammer/dolly routine to flatten out. So I got it as good as possible. I had an idea about finding some door edge guard material, U shaped, to slip over the edges of the cover. Will mess with that later.
Riv Nut Recess Dimple Die Set - 4 Piece
While I'm waiting for the 3" pie cuts, I trimmed down one of the straight reducers in preparation then removed the mufflers from the pipes. Lighten up the load some while I work at fitting pieces up.
The 3" pie cuts came in today. Came up the a good combination on the lh reducer. Used some duct tape to help hold the pieces together then tacked it together. Went to the rh side and it looks like I need to cut the collector and put at least one pie cut in to get the ball started on that side.
Today I got the rh side squared away. Cut the collector, put in one pie piece, checked the fit with the cut down reducer. Good to go so I marked it, then got it tacked up. Put the trimmed reducer on, used two pie cuts along with the piece trimmed off of the reducer, checked/clocked pie's for best combo, marked then tacked together. Put the mid pipes unit in the general area. Next go around will be to figure out what's needed there.
Cut the straight front part if the X. Easy peasy. I do quite a few custom X pipes since the EPA overstepped and closed down a few exhaust manufacturers
I'll be dissecting it in a few areas from my initial views. Need to ponder what/where/how on the next go around. Today I went ahead and welded up the reducers.
Couldn't readily find any aluminized units. So I was thinking last night, buy some material and diy my own.
That looks like a Gear Vendors unit in there.
It is! My got a great deal from the recycle yard unit that ended up being as much as buying new. Was behind a Ford, so needed the correct housing plus the unit itself was torched due to being in an overloaded RV. Won't make that mistake again when its time to do the wagon.
For some reason, I thought you were going to put a Tremec in the car.
The Gear Vendors company REALLY sticks it to the people that try to save a few bucks. The extension housing adapter seems to be cast in GOLD or something.
They do have an exchange program for both. Luckily for me at the time, GV was a 40 minute drive to get to. Price wise the GV was the least offensive and easiest to deal with on an automatic. Since my truck is a 6 speed manual and the car is an auto, plus when I first started on it Keisler was the only manual[ plus pricey], I kept the slush box. The trans was done by Pro Trans when they were still in Lancaster. They built it to class 8/trophy truck specs due to how I plan on using it. Also Continental made up a converter for me with all my supplied specs and usage plans.
